Bolt sizes
89_trailboss
89 Path. looking at 3" BL but its missing 2 or so bolts(ones for the actual body mounts). what is the bolt size (length/thread pattern) for the body mounts? are the nuts welded on or could I just go and get a set of long 8.8 bolts/nuts and use them?
Thanks
can anyone confirm 88's numbers? I asked the same Q on AC and the instruction manual for a 92 said that there:
2 Rear Mount = 10x180mm
2 Middle Under Door = 10x180mm
6 Body Mounts = 3/8x7"
Like I said, those are from a instruction manual for a BL for a 92 so maybe thats why there different. I dont know.
