Little project
Earth1
I was uploadind photos for the engine swap and thought I'd throw these up here. Can anyone guess what it is? Still a work in progress.
Hint: upside down in 2nd pic
Edited by Earth1
Whatever it is can you also make a templet to shield starter from oil filter changes? That would be a useful project.
That's a good idea to add to the list.
I'll take k9sar's answer. Heat sheild to cone filter. Got sick of it bouncing around and seeing the zip ties. Gonna use some c-channel around the bottom, sides and hole to reduce the vibration and some foam backer rod at the top to seal it to the hood. It's ready for some paint and then I'll tack on the edging. It'll go in with the new motor.
Edited by Earth1
