PCV Valve Location?
Guest jiffy
Guest jiffy
My mom has a 1999 pathfinder and yesterday I checked the air filter, which was filthy and had some oil on it. I replaced the air filter and then I went searching for the PCV valve so I could replace that as well. 30 minutes of searching and no luck.
Does anyone know where this thing is located? I've got to think that if it is so tucked away that I missed it, it will probably be a challenge to replace, and that I should just take it somewhere and let them do it. However, if it isn't too difficult to get at I'd just do it myself.
Thanks in advance.
i am not 100% sure where it is located on an R50.. but try on teh LH side of the motor (driver side) on the intake.. if you don't know what it looks like i can show you a pic of mine on my wd21. it is very easy to change.. don't get charged $200 for a 5 minute job ;)
Guest jiffy
Thanks everyone, especially for that pic lewisnc100. I would have never found it without that. It looked like some coolant hose, not a vaccum hose, so its no wonder I missed it.
Anyways, I found it and changed it easily. Thanks guys.
