interemitant miss
gillj
Let me start by saying that I love the sight both Mrjim.net and NPORA
My name is Jason I have a 91 Pathy 4x4 manual V6
And I love this truck its very capable never got stuck yet while I’ve been out playing in it
Im not a member of the NPORA as of yet but im going to join soon as I get pics of
My truck
I do have a few questions for you or anybody out there
My truck has an intermitant miss or something I cant figure it out
That just started about two weeks ago
Sometimes it will start and run fine and smooth for a while than start sputtering
And missing or something and sometimes it does it all the time
ive replaced fuel and air filters fuel pump new plugs checked resistance on plug wires
distributor seems fine im getting strong spark at all wires
Ran all my codes and nothing seems to be showing up im open for any suggestions
Is it likely that it’s the ECU itself or what
Please help
Thank you. And I do plan to join NPORA very soon
getting very frustrated :furious:
Jason.gill@med.va.gov
in the dark: lift the hood, start the truck, if you see a lightshow then the wires (or wherever the light comes from) is your problem.. could be crossed or cracked wires... could be the gap or the wrong spark plug, dirty dizzy cap will do it too.. vac line loose.. there could be a million things making it stumble.
guys i tried everything that you suggested allready
but i may have figured it out i hope so anyway
I unpluged the o2 sensor and drove it in mode #5 on the
ecu last night for awhile
and last night and so far all day today its been running good
and come to think of it it was acting like it was flooding out
god i hope thats what it is anyway
strange thing is I wasnt getting a code for O2 sensor
so i geuss only time will tell
does anyone know
When you put it in mode #5 does the ECU not monitor the O2 sensor at that time
i figured the mpg would drop
but until i get the 150.00 for the new O2 sensor
it will have to work
at least i wont be sputtering and shaking down the rode
any more info on exactly how the ecu works could be helpful
geuss what its still giving me trouble
could it be coil or distr it self would that come and go
and is there a way to test these if it was the ign control module it would just not run right?
any other suggestions
Hi when in mode 5 ,at idle you should get no codes, try getting the rps to 2000 while in mode 5 if you get steady blinks its the crank angle sensor. I to have a 91 and it sounds alot like the proublem i just fix.Change the distributor and she runs like new,they are exspensive but i located one on ebay for 30.00 bucks. You can read my posts for my problem under runs rough when up to temp.
when i say it wants to i mean at different times and with no other apparent causes just comes and goes whan it feels like it
all speeds all temps no matter what ive done so far even at idle
i will try what you suggest HJC
is there any way to test the distributor
hey, got all my info out of a service manuall for the 91, book is right out of the shop. there is no test for the distributor but the crank angle sensor is in the distibutor. mark the postion of the rotor and pull the distributor. when out leave power hooked up and spin the gears slow. you should hear the injectors opening. my shaft had a small amount of play in it . Like i said in mode 5 at idle you should get no codes,but in the service manuall it said to rev rpms to 2000 this is when i got the code for the crank angle sensor.when i started my post it only happened when she got to temp.but got worse as the day went by.if you want to talk email your # to punkin0823@cox.net
I think i might have figured it out guys
ive narrowed it down to cylinder#2 and its getting strong spark all the way to the plug so its either a sticking valve or injector
hopefully its the injector I guess ill find out as soon as i pull the injector out and check it
thanks everyone ill lett everyone know soon what it was
