SteveWA Posted January 8, 2006 Share Posted January 8, 2006 Park with the nose facing up a hill or steep driveway of say 10-20 degrees or so the Pathfinder won't start. Have to roll it level and then she'll go. Runs fine after starting, even up steep hills? Fuel Pump problem??? What do you think? Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted January 8, 2006 Share Posted January 8, 2006 How much go go juice is in the tank? Link to comment Share on other sites More sharing options...
SteveWA Posted January 8, 2006 Author Share Posted January 8, 2006 It was on 3/4 of a tank. It's happened twice now. Once in my mates driveway and again today when I was leaving the beach camp. Link to comment Share on other sites More sharing options...
kremmen Posted January 8, 2006 Share Posted January 8, 2006 If its a diesel, try priming the fuel pump, could be that or your glow plugs. Mine was starting hard when parked on a hill, so i replaced fuel pump and plugs and she is sweet now. Link to comment Share on other sites More sharing options...
SteveWA Posted January 8, 2006 Author Share Posted January 8, 2006 Opps should mention it's the 3.0l V6 not a deisel. Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted January 8, 2006 Share Posted January 8, 2006 I do not know if Australian delivered Pathies are different to the US models. Check your oil level. Just in case it is the same as a Holden donk and will not run unless the oil pressure is right. I suppose you should check if the fuel pump is running and test for spark at the injectors and plugs when it happens again. Apart from the Steve, it could be anytyhing causing it. Weird? Link to comment Share on other sites More sharing options...
SteveWA Posted January 14, 2006 Author Share Posted January 14, 2006 Anybody else have any ideas? Bueller...Bueller...Bueller...? Link to comment Share on other sites More sharing options...
94extreme Posted January 14, 2006 Share Posted January 14, 2006 how long is the truck parked like that before it won't start? can you shut it off and the immediately fire it back up? Link to comment Share on other sites More sharing options...
SteveWA Posted January 14, 2006 Author Share Posted January 14, 2006 The last time it was 2 days. But previously it's been maybe 2-3 hours. Link to comment Share on other sites More sharing options...
94extreme Posted January 14, 2006 Share Posted January 14, 2006 well, this kind of makes me think that maybe you're loosing pressure in the lines.. (flow back) so, next time you park it like that before you even try to fire it back up, check for pressure at the rail. there should be a schreader valve there which you just depress and if you get a spray of gas then that's not it.. then try to start it... check spark etc.. that's the only thing i can think of related to levelness of the truck.. not sure why the pump wouldn't just re-pressurise it when you click the key though. Link to comment Share on other sites More sharing options...
