A few questions
Maz
hey
this seems like a well informed board and I am wanting some more info..
1 what is the black box under the radio behind the cover mounted upsidedown by the vents
2 I found the ecu now how do I check codes I see it has led's is it like the honda where you count the flashes
3 What causes the rust in the rear rocker area within the doors is there a solution
4 Anyone have a pic of the trailmaster lift installed?
THanks for the info
Later
Jamie
Welcome to the boards Maz, many of your questions could have been answered by using the search function, but since I'm such a nice guy I'll answer the ones I know.
1. I don't know
2.http://www.nissanpathfinders.net/forum/index.php?showtopic=21
3. That would be caused by water mud snow salt, and is solved by welding over or replacing panels with non rusty panels.
4.
To elaborate on 88SC, its a weak point on the body, a seam. Depending on the damage, you could get by with just grinding off surface rust and repainting, all the way down to cutting the nasty stuff out if needed and welding in new metal. Its a common issue, and sorry that this is an incredibly vague answer, but the situation has many variables. As for cause, its a flat surface that collects water over some weld joints. Its bad design and a matter of time really.
1. that black box isnt it your abs box thingy. I could of sworn someone said thats what it was. my abs is fried and its gunna be death this winter but im pritty sure thats what it is....if not possibly one of the speaker amblifiers?
