Brendan91 Posted October 27, 2005 Share Posted October 27, 2005 This is the Body Lift I am looking at - how many years of experience in mechanics will I need to draw on to get this installed? I have my dad to tap - but can anyone give me a heads up what to watch out for? I looked at the howto, and there was no "howto" in it lol Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted October 27, 2005 Share Posted October 27, 2005 I have not got any pics of the body lift being done but I think there are some on here somewhere. The search function is not the best I have seen but keep on trying it. This is an Email I sent to exodus just the other day. I ran out of time for pics but will do them later and post them here............... The boby lift is very easy to do. I did mine off one trolley jack. A few tips if I may. 1. Help your brake lines to uncoil. (front) 2. Remove your steering rod completely form either the steering box or the steering column. If you just losen it and remove the bolt it can still jam and pull the column through the fire wall. 3. Remove the 'hoop' (behind your transfer case) around the rear tail shaft if it is there. 4. Rremove the lower part of your fan shroud. 5. Undo your fuel filler hose. 6. Back off all bolts but only remove one side at a time. 7. All of the bolt heads are held in place by the fit off caps so the nuts should turn without a problem. WD40 or CRC the buggers before you start though. I used a timber (post pic for you tomorrow) and with a grinder cut a slot down the middle of it so that the sill seem would sit in it. This does two things. 1. holds the timber in place and 2. gives better support to the body when you jack it up. ie. The sill will not bend. I also found that I needed to lenghten my handbrake brackets. I have not seen anyone mention this before other than me? I don't know if these things are included in the kit. There is alot of things in there. I will post pics for you tomorrow. I am sure this info is on NPORA so use it. Have fun with it. Enjoy finding the bolt heads. LOL. Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted October 27, 2005 Share Posted October 27, 2005 (edited) I found this while looking for info for something else. http://npora.ipbhost.com//index.php?showto...t=0entry29421 I did not know that you could extend the link between the column and the box. You really can learn something every day. Edited October 28, 2005 by Vsicks Pathy Link to comment Share on other sites More sharing options...
statikuz Posted October 29, 2005 Share Posted October 29, 2005 Not sure if you read this one already: http://www.nissanpathfinders.net/forum/index.php?showtopic=5325 Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted October 29, 2005 Share Posted October 29, 2005 It's all good! Link to comment Share on other sites More sharing options...
