Premature on my excitement
vidro
Jacked her up and yanked the tire this is definatley a much better view of the situation ... straight shot BUT what kind of drills or drill bits did you guys use?
Even though it is a straight shot it is to narrow to get a home drill in this area.
P1 is probably the man here for bit recommendations with his machine shop knowledge, but I used left handed titanium coated 135 degree bits. Center punch the studs first, start small and work your way up, tape an approriate depth on the drill bits so as to not go too deep. Slow, straight and steady are the orders of the day. And of course the penetrating oil of your choice.
We're all pullin' for ya. R. Green
M
On the drill thing, was that a Dremel type drill or a regular generic drill?
My standard drill will not fit between the wheel well and frame. Unless I have about a 5 inch long drill bit I will not be able to get to the bolt.
