MiSh Posted October 3, 2005 Share Posted October 3, 2005 Can anyone please tell me the collapsed and extended length of a terrano/pathy 3" lifted shock Link to comment Share on other sites More sharing options...
Precise1 Posted October 3, 2005 Share Posted October 3, 2005 While that has been mentioned several times, I can't remember.... Try here. http://npora.ipbhost.com//index.php?s=&act...rch&mode=adv&f= B Link to comment Share on other sites More sharing options...
MiSh Posted October 3, 2005 Author Share Posted October 3, 2005 have searched for the last 10min but cant find what im looking for. Link to comment Share on other sites More sharing options...
MiSh Posted October 4, 2005 Author Share Posted October 4, 2005 Does anyone know??????????????????????? I really need to know. Am getting some 3inch shocks but the arnt propper pathy ones and they give WAY more flex in the rear. But i need to know the length of the standard ones to know if they will fit Link to comment Share on other sites More sharing options...
Precise1 Posted October 4, 2005 Share Posted October 4, 2005 Ok Bud... I found this searching for "shock+length"... I'm using 5252's in front and 9114's in the rear on mine. The 9114's are approximately 3" longer than stock, with 11.5 inches of travel, as opposed to the stock 9118's 8.25 inches... I also have a different gas-charged set for the rear that have another 1.5" more travel in the garage Thats what 88 says and since he is the local Guru and has one of the tallest trucks, I'd say it's probably correct. Those are Rancho part numbers, so you can call or web search and verify them and the lengths/travels. From that you should be able to learn what you need to know, yes ? Good luck with your purchase, and it would be great if you tell us what you got, what you learned and how it works. Thanks... B Link to comment Share on other sites More sharing options...
