SLOVAK69 Posted August 18, 2005 Share Posted August 18, 2005 I m having problems with my highbeams. The low beem works on both lights, but when I switch to high beams, the drivers side high beam cuts out. I just replaced my drivers side light assembly, including bulbs both sides. Im guessing its a faulty connection or blown fuse. Has anyone had this problem before, was it an easy fix? Also, where are the fuses for the light circuit? I checked the one under the dash and the fuse box under the hood, they looked all ok. Am I missing something? Link to comment Share on other sites More sharing options...
Animal Posted August 18, 2005 Share Posted August 18, 2005 Do a search. You'll find info on cleaning the switch. Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 19, 2005 Share Posted August 19, 2005 Yep, it's your headlight switch. They tend to do that after a while. Link to comment Share on other sites More sharing options...
FLApathy Posted August 20, 2005 Share Posted August 20, 2005 yeah, on mine, only the pass side low beam comes on and on highbeam only the drivers side comes on, i took my switch out and the darn thing was shorted, there was burn marks all over it, i glad the dang thing didnt burn to the ground Link to comment Share on other sites More sharing options...
