n0cturne74 Posted August 6, 2005 Share Posted August 6, 2005 Any chance someone that has a Chiltons or similar book could post a wiring schematic? I'm looking to install a new in dash cd player and need the wire colors to basically hot wire it into the original system without using an adapter. Link to comment Share on other sites More sharing options...
94 Pathy Gary Posted August 6, 2005 Share Posted August 6, 2005 >>> HERE <<< ya go! Cheers! Gary Link to comment Share on other sites More sharing options...
n0cturne74 Posted August 6, 2005 Author Share Posted August 6, 2005 Thanks alot Gary!! That's going to help immensely Link to comment Share on other sites More sharing options...
kbreitwieser Posted August 6, 2005 Share Posted August 6, 2005 Why not get the adapter, I think they are only like ten bucks, and save you a lot of time, plus if you ever want to put in the old stock radio again it plugs right in... Whatever you choose to do, Good luck... Link to comment Share on other sites More sharing options...
n0cturne74 Posted August 8, 2005 Author Share Posted August 8, 2005 (edited) I'm Probably going to go with an adapter after contemplating the entire thing. I started pricing receivers in crutchfield and they also recommended an OEM amplifier adapter here It has the option to turn down the wattage from the receiver in order not to overpower the factory amps and is $40 which I wasn't too happy about. I have 8 speakers. (4 5X7's, 4 super tweeters...all still stock) Does anyone have any idea roughly how many watts the factory amps provide to the stock speakers? Is one of these things necessary with a head unit that's 45X4? I'm also contemplating disconnecting the 4 tweeters and just replacing the 4 woofers with 3 way speakers. I guess all in all I'm trying to avoid taking out the factory amps and running all new wiring to the speakers. Edited August 8, 2005 by n0cturne74 Link to comment Share on other sites More sharing options...
SteeevO Posted August 8, 2005 Share Posted August 8, 2005 (edited) I had the amp hooked up at first but they diddn't sound as clean as it does straight from the head unit. i ran new monster cable speaker wire. i'm not running an amp but i am running an eclipse head unit CD5444 (55WX4 output) with JL audio XR650-CSI in the front and XR-570-CXI in the back. i also dynamated the front doors....it made a huge difference in sound my pathy is a 1990 ..FYI Edited August 8, 2005 by SteeevO Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 9, 2005 Share Posted August 9, 2005 Just run new wiring to the speakers and avoid the amps completely. It'll sound much better. Link to comment Share on other sites More sharing options...
SteeevO Posted August 9, 2005 Share Posted August 9, 2005 Just run new wiring to the speakers and avoid the amps completely. It'll sound much better. ha thats what i was trying to say... Link to comment Share on other sites More sharing options...
