Drivers Side Window Problem
95Finder
My front drivers side power window has not worked since I bought the Pathfinder. I thought it was the switch at first because when I push the up button I can hear the motor trying to put it up and sometimes actually see the window get pushed up a bit. When I push the down button nothing happens. Today I went to a salvage yard and got a new switch assembly...it does the same exact thing that was happening before. Is my motor bad or could it be the wiring? I just don't understand why the motor would still be able to go up but not down. Thanks. Later.
