NastyPathy Posted June 16, 2005 Share Posted June 16, 2005 Iam getting 31X10.5 tires next week and is there anything i have to do or am i all set when putting them on. Will the cv boots be fine?? thanks for any feedback Link to comment Share on other sites More sharing options...
nick1716 Posted June 16, 2005 Share Posted June 16, 2005 make sure theres enough backspace on the rims to clear the strut. cv boots will be fine.. you only need to start worrying aboot them when you lift your pathy. and shoot even if you do tear one its nothin a little bit og shoe goo ant fix Link to comment Share on other sites More sharing options...
kmgar99 Posted June 18, 2005 Share Posted June 18, 2005 I used the stock rims on my 97 SE with BFG AT KO 31x10.5x15"s....No rubbing issues. You really don't need to go with aftermarket wheels or spacers until you go with a 32" tire Link to comment Share on other sites More sharing options...
NastyPathy Posted June 19, 2005 Author Share Posted June 19, 2005 Thanks guys Link to comment Share on other sites More sharing options...
94extreme Posted June 19, 2005 Share Posted June 19, 2005 if those tires are MTs then you probably will have some intermitten rubbing issues... may want to adjust your bump stops also.. may be rubbing on tight turns inside of the wheel well.. frame actually. Link to comment Share on other sites More sharing options...
