My AC doesn't blow any air
swamper
Hey guys just wondering if anyone has had this same issue? My AC in the 97 doesn't blow any air on any setting I replaced to blower motor and checked the fuse but nothing. Any ideas or has anyone had a similar issue? It sometimes will work randomly every couple of months. The air that does blow through from wind is cold. So it still works just don't blow.
I had a similar issue, and the culprit turned out to be a loose wire, the one that connects to the blower connector. I used some hot glue to hold it in place, and that solved the problem.
