1988 pathfinder starts, runs, and drives just fine, but I have no lights. Interior and Exterior are dead.
CountEjacula
Hello everyone,
Got the starting issue sorted on my pathfinder, and drove it for a bit, now I don't have any lights, nor do I have any accessories. Exterior and interior. All my fuses are good, and all my relays are clicking. Ignition switch is sending power, where it should. Is there something I'm missing?
Any and all help would be appreciated. Thank you.
Hey Slart, I've got the fusible links "bypassed" and I've just installed a couple of inline fuses. Previous owner messed that up a little so I figured it's best to make it fused. Is there anything there that could cause other problems?
For anyone that finds this, I managed to fix it. I was getting voltage across the line for my "fusible link", but I ended up pulling the fuse anyway and reinstalled it. Lights kicked on no problems. Super weird.
Good to hear you got it, though I would do some digging into that fuse setup to see what's making lousy contact. I lost the headlight circuit one night when a cheap in-line fuse holder that I'd used for my relay harness straight-up melted. Luckily the fog lights still worked.
