Speed Sensor
Loon
Wire broken 2-3 feet from sensor.  Thinking simply repairing the wire and heat shrinking should fix the problem unless I'm missing something.
Thoughts?
Next is the 4wd indicator wiring at the same place that is broken.
Don't see why not. If it's been broken for a while, you may have to cut back a ways on either side of the breaks to find clean copper and fill the gap with new wire.
Might've mentioned before, but the marine grade heat shrink with the hot snot inside is the good stuff.
