Rust question on 1998 r50 se
Ahupp
:welcome:
That's gonna need some welding. Dbot had similar rust on his, and was planning to rebuild it, but it doesn't look like there's gonna be an update on that one sadly. There was more of his left, though, so his pictures may give you a better idea of what it's supposed to look like--and his measurements are a good example for what you'll need to do to make sure it goes back together afterwards. Take a bunch of measurements and make cardboard templates before cutting into it. Both will be good to have when you've got a bunch of rot cut out (there's always more than you think there is) and you realize you're building something important, from scratch, in empty space, and if it's not in the right place, other things won't fit right.
The layered construction will make it a bit annoying, but at least the thinner metal's easier to bend. Rebuild with fresh steel of the same thickness as the original (measured where it's not rotten). Looks like you'll need a new bolt as well, and it would be a good time to do the bushings in the panhard rod if they need it.
