Fusible Link stuff
Frenchy
So I am currently in the process of changing the starter cable along with the alternator charging cable and all the fusible Link connections to the more modern fusible Link block that Nissan has on the newer vehicles(I think the design chang happened in the early to mid 2000's). With that said I am trying to figure out all the different amp ratings of all the fusible links. I know there are 3 different colors for the 5 that come off the battery. You have the Green that is rated for 40 AMPS and the Black that is rated for 80 AMPS. There are also the 3 Brown Fusible Links that supply power to the ECM and Headlights, but I don't know the rating for them.
Who might know the actual rating?
BTW I have already seen the color code chart posted on other Forums and they only mentioned Pink, Green, Red, Yellow, Black and Blue. It did not mention Brown at all. And no I'm not going to take the wire off to match it up.
