1996 R50 wiring diagram
Jannis
Hi, looking for advice and or where to download wiring diagram
My fuse keeps blowing for the rear tail lights,  I need to know what else is fed by the fuse, any thoughts  or advice would be much appreciated.
Nicoclub has the US-spec service manuals here. Hopefully they're similar enough to what you're working with. The EL section should have what you need.
If the R50 is wired like the WD21, the tail lights, front corner lights, dash lights, and license plate lights are all on the same circuit. If you've been into any of that recently, or if any of the lights aren't working, start there. When mine popped, it was because the wiring I'd recently modified for the license plate light had shorted out (the cheap heat shrink slid off a joint, which is why I use better heat shrink with glue in it now). If you have no leads to follow, check the exterior bulbs. Look for corroded sockets, loose wiring, or defective bulbs. If you have a trailer harness, check that too.
