rx_o Posted March 23, 2023 Share Posted March 23, 2023 (edited) Hi everyone, this is my first post here. I bought my Pathy last February ('02 SE Gold 100,000km/60,000 miles). I have learned a lot from this comunity, and feel that have I not read all the info in here, may have busted the car long ago, specially regarding the power valves screws fix and the IACV gasket replacement. Now I'm having some minor details. Oil consumption is about 1quart every 5,000km. Seems that I have pinpointed the leak, but I really haven't found any other post with a similar issue. I really don't know what the name of the part is, where the oil leak is, but I attach some pics to see if anyone can help me. I'm guessing that I just need to replace the screw gaskets (hopefully), but just need to check with the expterst here first. Edited March 23, 2023 by rx_o Link to comment Share on other sites More sharing options...
rx_o Posted March 24, 2023 Author Share Posted March 24, 2023 UPDATE: It was suggested that it may be the Camsahft Sensor (23731-2Y523). Will try to replace the oring firts, since sensor seems to be working fine. Link to comment Share on other sites More sharing options...
tobin_r50 Posted March 24, 2023 Share Posted March 24, 2023 Let me know if this stifles the leak, I also have a minor oil leak somewhere in my engine bay and may try this as a fix. Good luck! Link to comment Share on other sites More sharing options...
rx_o Posted March 24, 2023 Author Share Posted March 24, 2023 UPDATE As suggested I changed the oring. Here is the picture of the area cleaned and with oring replaced. Will post new picture un about 4 weeks to see if it keeps leaking. Link to comment Share on other sites More sharing options...
ramdala Posted March 24, 2023 Share Posted March 24, 2023 34 minutes ago, rx_o said: UPDATE As suggested I changed the oring. Here is the picture of the area cleaned and with oring replaced. Will post new picture un about 4 weeks to see if it keeps leaking. Do you have p/n or link of the oring... I guess it is the same problem I'am having Link to comment Share on other sites More sharing options...
rx_o Posted March 25, 2023 Author Share Posted March 25, 2023 2 hours ago, ramdala said: Do you have p/n or link of the oring Check in this link your engine configuration. 1 Link to comment Share on other sites More sharing options...
yourmomsbull Posted March 25, 2023 Share Posted March 25, 2023 12 hours ago, rx_o said: Check in this link your engine configuration. This is a common spot for a leak. Any Nissan/infiniti dealership will know the o-ring since it fails on the g35. 1 Link to comment Share on other sites More sharing options...
sdj539 Posted December 30, 2024 Share Posted December 30, 2024 Did the o ring solve the leak. That sane spot on my 02 is basically covered in built up oil sludge/residue. I had been thinking that it was either the camshaft position sensor or the vvt solenoid. Had planned on replacing the vvt gasket and the o ring on the cam sensor just curious if it solved your problem. Link to comment Share on other sites More sharing options...
