Led turn signals
Fratt3
I have an 03 se, i want to put leds in front and rear turn signals. I put them in rear and got hyperflash, added a load resistor and still got hyperflash. Any ideas? Thanks
If you got hyper flashing after the resistor, then the resistor was too small or you did not install a resistor for each of the four bulbs. The relay flasher is great, but you also have to remove the resistor(s).
Sent from my Pathfinder
