Valve Cover Gasket... rocker arm colors... reading the oil gunk?
Mattmill91
Any ideas on why some are dirtier then others...
First time open since factory I would think... changed the gasket.. would any of this benefit cleaning? Or would that make things worse?
Def some sludge up there.... but I bet there is a lot worse out their. 1d91dcc17485048d03d327de1bac28bf.jpg
I just did the easy side this evening. Luckily that was the only side leaking like crazy. It had a big break in the gasket witch was hard as a rock. Lucky I have had a new sitting on the shelf..
Mostly it follows your oil change interval and type of oil.
This is 7000mile oil changes with havoline and castrol dyno oil:
This is an unknown interval and oil type:
This is the same cylinder head at 3000-5000mile oil changes with top tier synthetic oil:
I agree with Slart, that discoloration on your rockers is probably from the PCV system.
