94 rear door window regulator
Guest juliantayloring
Whats up people,
The rear passenger side window took a dump on me the other day. I had to prop it up with a freakin 1x4.
The window lowered but refused to raise again. I tested the wires from the switch at the motor connection and they worked. I'm assuming the motor went bad.
I done some searching on the net and have found several places slanging the complete front regulators but none for the rear. Does anyone know if they're the same???
Anyone have an extra one they want to sell me. Any info is appreciated.
If you just need the motor and whatever it's hooked to I know of a 91 4 door in a junkyard close by that I've been picking apart for a while now... I'll check the cost, but the guy is REAL reasonable... He gave me the rear window switches for free when I asked how much he wanted for'em... Charged $10 for a coil, $15 for a stock crome rim, $1 for the front tow hook, ect... Just let me know if you want me to call the place for a price check... Or you can call if you want...(281) 530-6800 it's a Houston #...
