help speed sensor adapter?
jambrck
changed out transmissions in pathfinder went from a 95 transmission to a 91 but gear on end of speed sensor for 91 is smaller and does not come off and 95 sensor gear is bigger and comes off but cant find gear to replace
There are different-sized speedo gears available for these. There were two final drive ratios and two tire sizes available, so rather than make different clusters for each combination, Nissan just used different tooth counts on the gear for the speed sensor (or speedo cable on earlier models).
This might help clear things up. More part numbers here (second to last post).
  • 5 weeks later...
As much work as it is to R&R one of these transmissions - I cannot imagine in a million years putting a different, used one in place. Why would you do that? What a waste of time and effort. Shoulda just rebuilt the one that was in it. Or at least removed it and took it somewhere to have it rebuilt if you can't do it yourself. Now you got a pretty significant issue. Good luck!
