Help please tbi issue
So I fudged up and broke the wires off my tbi system to my 89 pathy left it on my table when I went to work and my brother threw them away :(  i cant find them online besides the wire up ones can I buy the plug and injectors I can't find them anywhere? The injectors and these two two spring plugged type deals with the plug that hooks into the harness!  Help meh pleeez!
If you're talking about the injectors harness, I would suggest to buy some standard automotive waterproof connectors, cut off what's left of the old connectors/wiring, and rewire the throttle body using the new connectors.
If you lost the ones that go into the MAF sensor or the TP sensor, instead, I would use some fastom connectors. Little more tricky and needs to be waterproofed someway afterwards, but better than nothing.
