D21 Parking Brake Installation into WD21
OH6PILOT
Well, I've gone and done it. As part of the new motor installation into the Black Pathy, I decided to do a NUMBER of upgrades, which include 3" suspension lift, wider center console WITH CUP HOLDERS, and removed the WD21 Parking brake and installed a D21 Brake. SUCCESS!!!
$20 on ebay for the Brake Handle assembly, and $23 for the brake cable (NEW) online. I could have gotten the brake cable at the JY for $5.00, but I didn't want to screw around with an old cable, plus the BS of trying to remove it with an engine installed...
I've read on here a number of people asking about it, but haven;t seen much in regards to people who have actually done it, so...here you go!! Total Time for installation, roughly an hour and a half.
INSTALLED.
Engine Firewall Brake Cable Access Plate Removed
Inside View Of Mounting Hole (Lower) The funner spacer thing STAYS.
Upper Mount Bolt Plate (Remove Bolt and Zip Tie Wire Bundle Higher
Installation Direction (Yes, looks weird) This isn't an easy fit, and it's a bitch when you're barrel chested trying to fit under the steering wheel.
eBake Bracket in place
Upper Mount Bolts Installed
