Gas fumes 94 pathy
porridgebird
Hi yall. I have a 94 sev6 pathfinder and I noticed a strong gas smell coming into the cab on the way home today. Ive checked for wet evidence of a leak but none found. Any Ideas? Thanx in advance😬 It smells strong in the front of engine when I popped hood and inspected. Nothing noticed with fuel lines from tank forward.
That is most likely the two high pressure fuel hoses that run between the left and right bank of your fuel injectors. They aren't difficult to replace but it is an involved process of removing the upper portion of the intake, the throttle body, small items items (IACV, throttle position sensor, and the fuel pressure regulator). The hoses them selves aren't easy to get on since they are only 4 inches long and you don't have a lot of room to work them into position. but it _is_ do-able. There should be a write-up over in the Garage section, other wise they _must_ be a post about that elsewhere on the forum!
