neilca Posted November 26, 2017 Share Posted November 26, 2017 I have searched here and on the web without success. So has anyone successfully replaced the lights in a manual climate control panel? The AC button light works but the fan, temperature and distribution panels are dark in my truck. I had it apart the best I could without removing the cables and I could not see any light sockets. 1 Link to comment Share on other sites More sharing options...
PibeGuerra Posted November 27, 2017 Share Posted November 27, 2017 Hi man, I did that fix today, there are actually two light bulbs that illuminate the whole AC control panel. Getting to them is actually pretty easy, but you have to dismount the A/C controls, because the lights are on the back of the panel: They should look like this: The blue color is actually a little rubber cover, be careful not to tear it apart or you will end up having a yellowish color on your AC controls, that happened to me at first, so changed the bulbs for white 12v LEDs and now it is looking good: I hope this helps, man Link to comment Share on other sites More sharing options...
PibeGuerra Posted November 27, 2017 Share Posted November 27, 2017 Had a problem uploading the pictures. Here you go:First:Second: Third: Link to comment Share on other sites More sharing options...
neilca Posted November 28, 2017 Author Share Posted November 28, 2017 Thank you PibeGuerra That is exactly what I needed. So you pull the bulbs from the socket for replacement. It really helped to know where to find them. I think I will go with the LED's as well. And you don't have to remove the cables! Awesome. Link to comment Share on other sites More sharing options...
PibeGuerra Posted November 28, 2017 Share Posted November 28, 2017 Not a problem neilca, I am sure it will look great with the LEDs. Good luck with that Link to comment Share on other sites More sharing options...
neilca Posted November 28, 2017 Author Share Posted November 28, 2017 Do you have a part number or source for the LED lights you used? Link to comment Share on other sites More sharing options...
