transmission swap
mrspeedk
I have a 94 4wd and my ex girl has/had my old truck a 93 2wd. She got hit when some moronic idiot turned out in front of her. Entire front end is destroyed. 25 years down the tube. Anyway, she had the tranny rebuilt not even 10K miles ago and mine has at least 150k+...hence why I want to change them out or at least have it on the ready for when and if mine goes. Thanks for your input.
If they're anything like the MT, I don't believe that the transfer case will bolt up to the transmission. The output shaft on the transmission is likely different... But I'm not 100% However.... If you're going to make yours from a 4WD into a 2WD, No biggie. I would keep the drive shaft from the donor in case they're different.
