ryjaytay38 Posted July 2, 2017 Share Posted July 2, 2017 Hello guy, Does anyone have any ideas where I can get this sensor? Everywhere I look, the part that comes up is cam shaft position sensor. Is it one in the same? I can't find any sites to order anything that says "intake valve timing control sensor". I feel like I'm chasing my tail and refuse to pay the dealership prices. Does anyone know the part number I need? Any suggestions would be welcomed!! Thanks!! Link to comment Share on other sites More sharing options...
onespiritbrain Posted July 2, 2017 Share Posted July 2, 2017 (edited) https://www.autocodes.com/p1140_nissan.html That sounds like a sucky problem Sent from my iPhone using Tapatalk Edited July 2, 2017 by onespiritbrain Link to comment Share on other sites More sharing options...
Exorpmtech Posted July 2, 2017 Share Posted July 2, 2017 (edited) https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.googleadservices.com/pagead/aclk%3Fsa%3DL%26ai%3DDChcSEwjdgPaoi-rUAhVQG4EKHeStCmsYABAIGgJ5dw%26ohost%3Dwww.google.com%26cid%3DCAESEeD2sI1wA2-M1wTfB8v2JOvX%26sig%3DAOD64_1oVMuZro2mkSDi2hGNgvV83QmrUw%26adurl%3D%26ctype%3D5%26q%3D&ved=0ahUKEwjdxPCoi-rUAhUJ64MKHYBBCvUQ5D4IIQ&usg=AFQjCNH1cB-hVgtm1RAmw7PLYkBz8Heqxw Edited July 2, 2017 by Exorpmtech Link to comment Share on other sites More sharing options...
Exorpmtech Posted July 2, 2017 Share Posted July 2, 2017 That should be it. Ill let you cross referance the part number.. Link to comment Share on other sites More sharing options...
Exorpmtech Posted July 2, 2017 Share Posted July 2, 2017 (edited) Oops..double post Edited July 2, 2017 by Exorpmtech Link to comment Share on other sites More sharing options...
Exorpmtech Posted July 2, 2017 Share Posted July 2, 2017 ...and the code states it could be the cam sensor or control solinoid. If the other cam sensors are the same (dont know off the top of my head, mines a 3.3) you can swap the sensor with the other cam or bank, clear the code and see if the code follows to another location. If it stays the same id check the wiring to the cam sensor first, signal and ground is my guess if its a two wire connector, which im pretty sure it is. If that's good check for signal/ground to the solinoid and check the resitance spec on the solinoid. If the wirings good id replace the solinoid. The solinoid may also show to be out of spec as well checking the resistance. Link to comment Share on other sites More sharing options...
Exorpmtech Posted July 2, 2017 Share Posted July 2, 2017 (edited) Sorry, last thing...A p0340 is for the actual cam sensor, another reason I suspect the solinoid. Edited July 2, 2017 by Exorpmtech Link to comment Share on other sites More sharing options...
Exorpmtech Posted July 2, 2017 Share Posted July 2, 2017 (edited) . Edited July 2, 2017 by Exorpmtech Link to comment Share on other sites More sharing options...
ryjaytay38 Posted July 3, 2017 Author Share Posted July 3, 2017 So you think solenoid rather than sensor? I found the part number on another forum and when I put it in to different sites it says camshaftsensor/intake valve timing control sensor as if they are the same thing or one can be used for the other. Is that possible? Link to comment Share on other sites More sharing options...
Exorpmtech Posted July 3, 2017 Share Posted July 3, 2017 It sounds like they are the same sensor, IE, it uses the cam sensor to also monitor the variable timing. Reguardless you're just guessing unless you get out there and do a little diag. Link to comment Share on other sites More sharing options...
ryjaytay38 Posted July 3, 2017 Author Share Posted July 3, 2017 Very true. Thanks a lot for the good advice. I'll let you know what I find Link to comment Share on other sites More sharing options...
Exorpmtech Posted July 5, 2017 Share Posted July 5, 2017 let us know! Link to comment Share on other sites More sharing options...
