maddmark1981 Posted March 27, 2017 Share Posted March 27, 2017 Im in a pickle guys. Ive been having charging issues lately I want to take my alt off and bench tested so I remove 2 bolts from alt. Top and Bottom. Removed belt and loosened adj. Bolt. And she would only turn under force but did not come loose. Should I remove wires before or after taking the bolts out? Sent from my LG-H812 using Tapatalk Link to comment Share on other sites More sharing options...
onespiritbrain Posted March 27, 2017 Share Posted March 27, 2017 Take all the wiring off while it is still secured. You want to put the wiring back on the new alternator after it has been secured so you know you don't have loose connections. What exactly is your problem? One of the alternator bolts won't come out? Or the belt tensioner bolt isn't working? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
maddmark1981 Posted March 27, 2017 Author Share Posted March 27, 2017 Take all the wiring off while it is still secured. You want to put the wiring back on the new alternator after it has been secured so you know you don't have loose connections. What exactly is your problem? One of the alternator bolts won't come out? Or the belt tensioner bolt isn't working? Sent from my iPhone using Tapatalk I can only see 2 bolts and when I took them out the alt was being held in place Sent from my LG-H812 using Tapatalk Link to comment Share on other sites More sharing options...
vagabond Posted March 27, 2017 Share Posted March 27, 2017 (edited) top of the alt is 2 bolts 12 mm heads remove them, also if you follow the wiring back to the plugs you could disconnect there and pull the wiring with the alt, personally I'd disconnect at the alt Edited March 27, 2017 by vagabond 1 Link to comment Share on other sites More sharing options...
