R50 AC vents wont blow
Saturn
So after a recent off-road bout my upper a.c. vents i, the cabin won't blow. When I run the AC on I can hear the fan and everything start moving, and the vents in the footwells work perfectly but nothing comes out of the vents in the dash. I pulled the glove box out and the cabin filters were dirtt, I'll change them, but I started the system without the filters and still nothing from the vents, even when I sealed the slot for the filters. This is really frustrating, the AC system obviously works, it just won't blow out of some of the vents. 2002 LE by the way, electronic HVAC controls. I've looked around and no one else seems to have this problem. Any ideas?
Edited by Saturn
There is a full diagnostic procedure for the electronic hvac in the Factory service manual page HA-45. With that you will be able to test everything on it from led to mode and intake door motor as the input signals too.
I suspect the mode motor which is under the steering wheel, on the right (directly on the left underside of the center dash).. With the fsm, you will also be able with an voltmeter, to test if the motor is still good or if it is a piece of something that is stuck in there...
s.
Problem found, my blend door actuator went out on me. None of the parts stores near me have it so its gonna be a dealership or junkyard trip, in the meantime i managed to get the blend door all the open with a screwdriver, so the AC blows hot all the time, but at least I can just roll down the windows when it gets hot. Thanks for the info everyone!
