Help in identifying sound from Right Bank of VG30E Head
shogunb
Need help in identifying sound coming. I posted the video on youtube.
Replaced Knock Sensor. Before that completely removed the right cylinder head to drill to fix broken exhuast studs in the head. Reclocked TDC for Crank off of No.1 cylinder and reset timing based on that.
It Idles fine. Drives fine. No Errors Codes.
I'm wondering if I burnt a valve up when I had a exhaust leak through the exhaust header gasket. Replaced Gasket today sound didn't leave. Maybe the mating surfaces aren't flat and exhaust gassing are getting by.
Hopefully someone has a idea or two.
Cheers
Shogun
  • Confused 1
That is definitely an exhaust leak. Either from a warped manifold or where the 3 bolt flange is. I fixed that exact same noise on my dad's 93 HB. It was from broken studs too.
Did you scrape and sand down the mating surfaces on the manifold and make sure all the bolts/ nuts were able to be tightened down completely?
Sent from inside my potato
  • 6 years later...
  • 4 months later...
Definitely exhaust gasket, if it sounds like its right on the head its manifold gasket, if it sounds like behind the head its the crossover tube gasket. Make sure you cinch it down so the gasket sits evenly. Loosen it and tighten again if you have to.
