Cuong Nguyen Posted October 29, 2016 Share Posted October 29, 2016 I am looking for photos of the fuel feed lines and return to the fuel rail. I want to make sure I did have it hooked up right and see if orientation matters. Link to comment Share on other sites More sharing options...
RCWD21 Posted October 29, 2016 Share Posted October 29, 2016 (edited) I'm not sure if this posted earlier or not but the pic is sideways on here so the top fuel line is the one coming from the filter, it goes to the fuel rail inlet which is the forward most metal line. The return is the bottom fuel line and is the rear most metal line. *If this is a double post then please delete it as I posted this morning but when I open this sub thread nothing but the original post shows up. Sent from inside my potato Edited October 29, 2016 by RCWD21 Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted October 29, 2016 Author Share Posted October 29, 2016 It's a double post Link to comment Share on other sites More sharing options...
RCWD21 Posted October 30, 2016 Share Posted October 30, 2016 Ok, it still doesn't show my first post but I hope it helps you out. I've been working for 5 hours trying to get the metal clutch lines mounted and stretched to fit the body lift. It's a pain mounts the rubber line without that clip to hold it tight to the bracket Sent from inside my potato Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted October 30, 2016 Author Share Posted October 30, 2016 The firewall clips that hold my brake lines broke over the years since I didn't stretch them enough. Link to comment Share on other sites More sharing options...
RCWD21 Posted October 30, 2016 Share Posted October 30, 2016 Mine shattered like glass when I jacked up the body. My lines are all bent weirdly anyways so I don't see the point in replacing the clips. I'm just going to run plastic wire loom over them to help gaurd them from abrasion and to help hide them a little bit. Sent from inside my potato Link to comment Share on other sites More sharing options...
