Harbinger Posted March 15, 2005 Share Posted March 15, 2005 My 4x4 indicator light isn't working, I'm confidant that the 4 wheel IS working however, just due to my "testing" in the desert. Is there a bulb to change? Is this the voltage regulator issue? Link to comment Share on other sites More sharing options...
denisb Posted March 16, 2005 Share Posted March 16, 2005 Mine had a broken wire off the differential switch. It's quite hard to reach and a pain to change/fix. You might be able to see if there is a broken wire off the switch by looking under your rig, on the right hand side of the transfer case, kinda mid to top. If you can't see if the wires are broken, the bulb is probably easier to check than the switch. Although it could be a burnt bulb it would surprise me. These bulbs have crazy lifespans. It's the same type bulbs used in your cluster illumination and unless you always have your rig on 4x4 (which is possible) odds are your cluster was on longer than your 4x4 light. I don't have time tonight, but if you want I can try to take a picture with my digital and e-mail it to you tomorrow. Denis Link to comment Share on other sites More sharing options...
