My 88 SE-V6
Brad251
Wow, super clean truck!
Looks like the torsion bars sagged out on the front. Stock should sit close to level with the rear.
If it's glued, a heat gun and some patience, with a follow up with an adhesive remover wheel would be your best bet.
The guy I bought it from said he adjusted the torsion to stock specs. I suspected he was not correct. Its very bumpy ride. So they may need to be re indexed and or some shocks. Not sure yet.
Sent from my XT1585 using Tapatalk
I actually have a tool that may work. Its made for removing 3m tape that holds things together. Just to separate them. If u think it'll work.
Yeah. The difference in height between the bottom of the steering stop on the control arm and the center of the pivot bolt should be between 1 3/4 to 1 7/8 of an inch.
It looks like yours is almost on the bump stops.
That tool should work, I'd still heat it up a bit to soften the adhesive.
Edited by PathyAndTheJets
I knew something wasn't right about it. Haven't had a chance to jack it up and adjust it yet. Thanks for the measurements. Its pretty clean. Has about half of the issues all of them have: small rust spots under back seat, headlight switch issues with only 1 bright coming on. Also I'm pretty sure that's the original spare on the back.
