ScottS75 Posted March 29, 2016 Share Posted March 29, 2016 Hello all. Kind of new on here, but love my Pathfinder, when I get to drive it(wifes daily driver). Would you recommend KYB front struts for this truck? If not what would you recommend? Looked at Bilstein's struts but apparently they don't list our vehicles any more. Thank you in advance. Scott Link to comment Share on other sites More sharing options...
cntryboy_88 Posted March 29, 2016 Share Posted March 29, 2016 Definitely kyb would probably be the best Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
cntryboy_88 Posted April 2, 2016 Share Posted April 2, 2016 What did you end up deciding on? Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
rickyspath Posted April 10, 2016 Share Posted April 10, 2016 When changing the front struts, should the springs be replaced as well? Sent from my SM-N900T using Tapatalk Link to comment Share on other sites More sharing options...
pepperjack26 Posted April 10, 2016 Share Posted April 10, 2016 Not a necessary part to replace, unless you are trying to get more height. I used the KYB on mine, but waited (month) for my OME springs to arrive. My goal was lift - and the struts were already gone. I've been told: if you are doing springs - do the struts. If struts are gone and springs are not damaged - struts alone are fine. Link to comment Share on other sites More sharing options...
Rebelord Posted April 10, 2016 Share Posted April 10, 2016 If you want to do both but stay stock height. Gabriel has a complete unit. But makes for a easy drive way swap out. Sent from my SM-G920V using Tapatalk Link to comment Share on other sites More sharing options...
rickyspath Posted April 11, 2016 Share Posted April 11, 2016 I changed the struts and shocks but not springs they seem fairly new. I found the old service manual and a ton of receipts the (mostly water damaged) but the springs are under 5yrs old Thanks for the help Sent from my SM-N900T using Tapatalk Link to comment Share on other sites More sharing options...
