oil_in_the_blood Posted March 17, 2016 Share Posted March 17, 2016 Hi All, Was sent here from reddit to ask some more specific questions. So I've got my eye on an 02 pathfinder LE, drives fantastic, shifts awesome. No milkshake, next to no rust etc etc. Only issue, ABS light is on. Now I tested the 4wd as much as possible (it's the push button one on the dash.) Would go into 4lo, and I could feel the difference in 4hi in the steering. So i'm ok with buying a vehicle that will not have functioning ABS for a couple of months as I track down and fix the issues with the system, I just want to be 100% sure that the only function affected will be the ABS and not anything else (i.e. it would effectively be a pathfinder without ABS.) I want to be sure that it will not affect the way the transmission shifts, or the way the 4WD works in any mode. Can anyone confirm this for me? Thanks for taking the time to read this. Link to comment Share on other sites More sharing options...
toughroad Posted March 17, 2016 Share Posted March 17, 2016 Could be a simply dirty abs sensor or busted. Run a diagnostic and see the error codes. About the tranny it won't affect it. Link to comment Share on other sites More sharing options...
fleurys Posted March 17, 2016 Share Posted March 17, 2016 I believe the auto mode will not work on your transfer case as I think it relies on the abs ''ring with teeth'' to detect wheel slippage and therefore activate the 4hi on the fly... direct 4hi or 4lo should still work though. Link to comment Share on other sites More sharing options...
toughroad Posted March 18, 2016 Share Posted March 18, 2016 I believe the auto mode will not work on your transfer case as I think it relies on the abs ''ring with teeth'' to detect wheel slippage and therefore activate the 4hi on the fly... direct 4hi or 4lo should still work though. He is absolutely correct with his statement. That is why you need to figure out how to fix the ABS. Link to comment Share on other sites More sharing options...
teixeira Posted March 18, 2016 Share Posted March 18, 2016 Link to comment Share on other sites More sharing options...
fasttunes Posted March 21, 2016 Share Posted March 21, 2016 Welcome! Howdy from the Sin City! Link to comment Share on other sites More sharing options...
