Spare tire rack rattle
My spare tire rack has rattled since I bought the truck in November 2015. I have a 94 wd21 manual tranny sev6. I haven't been able to isolate the cause. The unit feels very firm but if u pound on it with the palm of your hand u can duplicate the rattle. Any small bump in the road and it just rattles my brains out! Any experience out there? Thanks Randy
The bushings at the hinge are most like shot. If you open the carrier all the way and look at the inside of the hinge pivot, you should see a hole. You can try and pump grease into it and see if it helps, but a rebuild is most likely needed.
You could go and check to see if the strip of plastic on the middle support is still there. If it is, the rack has an adjustment to increase the tension on the rack at that location, but 5523Pathfinder is correct.... it needs a rebuild.
