Guest sweep Posted March 11, 2005 Share Posted March 11, 2005 Can anyone give me any tips and things to look out for on installing a standard tranny in place of an automatic in a 93 3.0 4x4 pathy? Any help will be appreciated. Link to comment Share on other sites More sharing options...
94extreme Posted March 11, 2005 Share Posted March 11, 2005 search in the garage or general.. i think that topic was up semi recently... Link to comment Share on other sites More sharing options...
Guest Jose Garcia Posted March 11, 2005 Share Posted March 11, 2005 Hi Sweep, my name is Jose Garcia. I just replaced my 94 Pathfinder auto tranny with a manual one. No problem. Evrything fit perfectly. I just had to by a flywheel and bolts cause they are longer for manuals. I had to order them through the dealership. Well here's a list of items I had to buy for the conversion: Flywheel Flywheel bolts Set of pedals (break/clutch at a local JY) Clutch Cylinder Clutch line Clutch and press plate Pilot bushing Slave Cylinder Slave Cylinder hose and bolt Shifters' boot The metal plaque where the boots sits Center console (for manuals, it's shorter) That's just about it. Considering your tranny comes w/ the shifters. Make sure you get the set of bolts for the bell housing; cause the holes are a bit longer than the auto tranny bell housing holes including the starter bolts. If you come up with any other question let me know. Link to comment Share on other sites More sharing options...
Guest sweep Posted March 12, 2005 Share Posted March 12, 2005 (edited) You are just the Person i am looking for, thanks for the reply!! How did you set up all the electrical connections on the manual? Do you need and new ecu for the Manual tranny? Edited March 12, 2005 by sweep Link to comment Share on other sites More sharing options...
