nick1716 Posted February 24, 2005 Share Posted February 24, 2005 is it possible to do a diff drop on a pathy??? like 4runners and tacomas? Link to comment Share on other sites More sharing options...
rosspbig Posted February 24, 2005 Share Posted February 24, 2005 Its possible, but it would be a custom job. Link to comment Share on other sites More sharing options...
96pfinderSE Posted February 24, 2005 Share Posted February 24, 2005 Whats a diff drop? Ive only heard of a sub frame drop. Tryin to learn somethin new here. Link to comment Share on other sites More sharing options...
nick1716 Posted February 25, 2005 Author Share Posted February 25, 2005 drop your front differential lower so your cv joints arent at that bad of an angle Link to comment Share on other sites More sharing options...
96pfinderSE Posted February 25, 2005 Share Posted February 25, 2005 Thats what i thought. I just call it a sub frame drop. Yea its custom job (i wish i knew how to weld). You have to drop the sub frame then lift the engine back up. Then say goodbye to cv problems Link to comment Share on other sites More sharing options...
nick1716 Posted February 25, 2005 Author Share Posted February 25, 2005 well i know how to weld..thats what im in skool for but on toyotas you dont need to do any welding...its just like a body spacer pretty much... like 2-3 inch in diameter by 2 inch thick (or how ever much drop you want) with a hole drilled in the center Link to comment Share on other sites More sharing options...
96pfinderSE Posted February 25, 2005 Share Posted February 25, 2005 Well i think that might work. But remember you have to lift the engin back up. so if you drop the sub frame 2inches you got lift the engine 2. keeps the tranny and driveshaft in line. Just use the idea and go with it man. tell me if it works an ill be right behing you on it Link to comment Share on other sites More sharing options...
88pathoffroad Posted February 25, 2005 Share Posted February 25, 2005 You guys talking about this type of kit? Link to comment Share on other sites More sharing options...
96pfinderSE Posted February 25, 2005 Share Posted February 25, 2005 I think those might be what hes talkin about. Would you be able to do with some minor fabs 88? Your guess is as good as mine Link to comment Share on other sites More sharing options...
nick1716 Posted February 25, 2005 Author Share Posted February 25, 2005 yea.. is that for an r50?? Link to comment Share on other sites More sharing options...
88pathoffroad Posted February 25, 2005 Share Posted February 25, 2005 SLR makes those for Frontiers/Xterras only. Click on the picture for more info on their website. I've never looked at mine to see what it'd take, but it may very well be possible. Link to comment Share on other sites More sharing options...
96pfinderSE Posted February 25, 2005 Share Posted February 25, 2005 I seriously think that could be done. If you could fab some bushings up like that. of find an almost identical car that can use that and use it. Link to comment Share on other sites More sharing options...
88pathoffroad Posted February 26, 2005 Share Posted February 26, 2005 From Brent(OffroadX) on the NOR forums: The SLR diff drop bushings will interchange with all Pathfinder, Hardbody, Frontier, and Xterra R200A diffs, the part numbers for the bushings/mounts/members are either the same or cross over. Brent So! If you have an R200A front diff, apparently the bushings are the same and these drop bushings will work! Link to comment Share on other sites More sharing options...
96pfinderSE Posted February 26, 2005 Share Posted February 26, 2005 HELL YEA! what model do those come in? THose would be so nice Link to comment Share on other sites More sharing options...
nick1716 Posted February 26, 2005 Author Share Posted February 26, 2005 how do you tell what difff you have?! Link to comment Share on other sites More sharing options...
