ShawnTRD Posted February 20, 2015 Share Posted February 20, 2015 Standard SE 265/70 16 vs Off-Road SE 265/75 16? Does the standard have any trouble with the slightly taller tires? Looks like they (75) will be cheaper then the 70 size. Link to comment Share on other sites More sharing options...
gv280z Posted February 21, 2015 Share Posted February 21, 2015 I seriously doubt it, why not just try going to a tire dealership and first just ask to compare the two side by side and you'll see the difference is almost imperceptible, it's about maybe a 1/4" to 1/2" difference, and then ask for a fitment test. If they do charge some kind of a tire mounting labor fee, I can't see that it would be that high and that would probably be only after they removed the new one and put your tire back on the rim, if you were to buy a set then I don't think they'd charge for a clearance fitting. Even if you do end up owing $40 - $60 bucks atleast you'll know for sure. Link to comment Share on other sites More sharing options...
