Ndillon14 Posted February 2, 2015 Share Posted February 2, 2015 My automatic antenna on my vehicle has been stuck and bent for some time now, and I'm looking to replace it with a non motorized stationary antenna, preferably one of the shorter rubber type ones. Whats the process to switch from the automated one to a fixed antenna? Thanks Link to comment Share on other sites More sharing options...
ferrariowner123 Posted February 3, 2015 Share Posted February 3, 2015 Find a fixed one. Pull passenger inner fender liner Gently use a pair of needle nose pilers to twist off the chrome trim ring, where the antenna goes into the car. Remove two (or three) screws that hold the antenna to the inner fender. Install new, fixed antenna in reverse order. It's a pretty straight forward swap. Only thing on wiring is not plugging in the motor harness. Just the single, thick black wire for the antenna. -Kyle 1 Link to comment Share on other sites More sharing options...
Karmann Posted February 3, 2015 Share Posted February 3, 2015 I bought by "Euro" antenna on Amazon, $13 and it's been perfectly acceptable after three years and some bushwhacking. Decent reception, and definitely looks better. Link to comment Share on other sites More sharing options...
ferrariowner123 Posted February 3, 2015 Share Posted February 3, 2015 Link? -Kyle Link to comment Share on other sites More sharing options...
lethalproductions Posted June 20, 2016 Share Posted June 20, 2016 So how did this come out for you? I'm looking to do the same and I had found an Antenna on Amazon. AntennaX The Shorty Antenna for... Curious to see before I buy it. thanks in advance. Link to comment Share on other sites More sharing options...
