Guest 87milpathfinder Posted February 18, 2005 Share Posted February 18, 2005 Greetings, I own an 87 Pathfinder w/ 150k miles on it, and my engine has recently started making a ticking/clicking sound. I checked under the common problems and read about the exhaust bolt issue, however the noise occurs when I have been driving at highway speeds (at 4000RPM - no overdrive) for about 20-30 mins. when I return to a slower RMP, the noise diminishes and the disappears after about one min. Also, the speed of clicking/ticking is proportional to the engine RMP. Any info would be much appreciated. Thanks, JP Link to comment Share on other sites More sharing options...
denisb Posted February 18, 2005 Share Posted February 18, 2005 almost sounds like your oil pump is loosing it's prime at higher RPMs. Could be a bad or cloged screen. Have your oil changes been done at regular 3000 mile intervals? You could drop your oil pan and check the pump for clogs or do an engine flush, install an oil pressure guauge and see what kinda oil pressure you get. Denis Link to comment Share on other sites More sharing options...
Guest 87milpathfinder Posted February 18, 2005 Share Posted February 18, 2005 Oil pressure gauge shows up good, however, the oil light come on occasionally after coming off freeway even when oil is topped off. Link to comment Share on other sites More sharing options...
Diesel Boy Posted February 18, 2005 Share Posted February 18, 2005 Lifters lifters lifters, check your oil level. Run some engine flush, oil change and new filters, see what that does. Link to comment Share on other sites More sharing options...
Guest 87milpathfinder Posted February 18, 2005 Share Posted February 18, 2005 Changed oil very recently, though I'll try flushing it and put a filter on it if that would help. Link to comment Share on other sites More sharing options...
Diesel Boy Posted February 18, 2005 Share Posted February 18, 2005 I didn't study your post well enough!!! Is the oil pressure still good on the gauge when the oil light comes on?? Link to comment Share on other sites More sharing options...
JeepRescueService14 Posted February 18, 2005 Share Posted February 18, 2005 if the noise quiets when you accelerate wide open or while coasting.. sounds like it might be the woodpeckers movin in. (rod knock - spun bearing) hard to say Link to comment Share on other sites More sharing options...
MatterHorn Posted February 18, 2005 Share Posted February 18, 2005 (edited) if the noise quiets when you accelerate wide open or while coasting.. sounds like it might be the woodpeckers movin in. (rod knock - spun bearing) hard to say I agree ... usually an indication of a poor break-in on a new engine ... hows the compression? ... would be worth a check as well for any possible cracks or broken rings ... oil pump could be a source of noise too ... take it to someone else or a shop and get a second opinion .... Edited February 18, 2005 by MatterHorn Link to comment Share on other sites More sharing options...
Diesel Boy Posted February 18, 2005 Share Posted February 18, 2005 Yeah, i was wonderin about bigends, as they tend to act up in that area between load and engine brakeing. They don't make a ticking sound thats all. Link to comment Share on other sites More sharing options...
Guest 87milpathfinder Posted February 22, 2005 Share Posted February 22, 2005 The oil pressure shows up fine when the light comes on. I'm going to try a engine flush soon. More info soon. Link to comment Share on other sites More sharing options...
