trans weight
stabworthy
I've been told you can drop the tranny without taking the torsion bars etc. off if you remove your transfer case first then pull the transmission. I've never done it, that way but it might be easier, that'll definitely reduce the weight on the jack
I'm fairly confident your jack will be fine, worst case, throw a trolley jack under the transfer case and scoot them back together. Make sure to pull the starter to get to the hidden bolts. Cross your fingers its& hope just the clutch, lol.
