ebayfish Posted November 10, 2014 Share Posted November 10, 2014 The joint between my idler/pitman arm & draglink has some play in it. I can't find just this link, northe name of it. Is it replaceable or will I have to get a complete new centerlink? Link to comment Share on other sites More sharing options...
5523Pathfinder Posted November 10, 2014 Share Posted November 10, 2014 You gotta be talking about the Centerlink(looks like a dog bone). Nope, none of the joints are replaceable. There are a few aftermarket options out there including a Grassroots Centerlink(I have this, its awesome), Calmini makes a new steering system( go to calminis website for details, but warning, some have had long wait times to get this), a 2wd steering swap(you gotta use the search function for that one) or replace it with another factory unit. If you offroad at all, I highly recommend one of the first two options. Link to comment Share on other sites More sharing options...
Nissanland Posted November 14, 2014 Share Posted November 14, 2014 I have the moog center link and have had no issues with it. It's been very good so far, I did use all moog parts when I replaced it and the drag link's/ball joints. Make sure to get greasable joints and avoid the sealed units that can't have a zert installed also. Really helps in the preventive maintenance side of things. As stated above the grassroots units are the best if you want the best but if cost is the factor go to rock auto parts and order the moog center link. Link to comment Share on other sites More sharing options...
Nefarious Posted November 14, 2014 Share Posted November 14, 2014 (edited) I've installed the 2wd swap in my girls pathy now using moog center link and problem solver inner tie rods and it is incredibly solid. She daily drives it and we wheel it all the time and it's still as tight as day one. The added benefit is less bump steer over stock since the lower control arm and tie rod articulation angles match up better. It won't be as durable as a calmini setup, but it solves and eliminates the horrible dog bone center link and replaces it with a standard 4wd ifs steering setup similar to a Chevy or a 4 runner. I've been rocking it for years in my truck and hers is even better than mine with the moog parts. Edited November 14, 2014 by Nefarious Link to comment Share on other sites More sharing options...
