PathfinderProject1988 Posted October 28, 2014 Share Posted October 28, 2014 just replaced both injectors, still not running right so we took a look and the injectors seem to be stuck open, but theyre both new. could this be a wiring problem? and i cant rev over about 2300rpm also does the temp gauge hook up below the right manifold? saw a plug just laying there not hooked up.. Link to comment Share on other sites More sharing options...
krmiller07 Posted October 31, 2014 Share Posted October 31, 2014 That's probably the lead to the oil pressure sending unit that runs to the 'idiot light' in the instrument cluster. When all 3.8 qts of oil are gone that light (if hooked up) illuminates just before your Con Rods blow out the oil pan ! Link to comment Share on other sites More sharing options...
