fuel injector problems help!
just replaced both injectors, still not running right so we took a look and the injectors seem to be stuck open, but theyre both new. could this be a wiring problem? and i cant rev over about 2300rpm
also does the temp gauge hook up below the right manifold? saw a plug just laying there not hooked up..
That's probably the lead to the oil pressure sending unit that runs to the 'idiot light' in the instrument cluster.
When all 3.8 qts of oil are gone that light (if hooked up) illuminates just before your Con Rods blow out the oil pan ! :/
