anperalta Posted September 8, 2014 Share Posted September 8, 2014 Well hello everybody I'm a little new around here since December last year I got my Nissan and now i'm having a misfire problem on #5 cylinder which is making me going crazy........... already check spark, spark plugs, cap and rotor, and is not a fire problem, I don't think that can be a fuel problem because its an tbi injected and al the others 5 cylinders works good. Make a compression test only in that cylinder and shows 150 psi.......... pretty well, what else can I check for? I'm getting out of ideas and already have 22 days whit this problem...... HELP please!!!! Link to comment Share on other sites More sharing options...
Kingman Posted September 8, 2014 Share Posted September 8, 2014 150 is pretty low but shouldn't be enough to cause a hard misfire. I'd do a leak down on it, and another wet compression test. How does the plug look? Link to comment Share on other sites More sharing options...
anperalta Posted September 9, 2014 Author Share Posted September 9, 2014 I change the plug of #5 with the plug of # 4 cylinder and still have the misfire on #5....... turn 180º the distributor cap changing the post of #5 to #2 cylinder. .... and still misfire on #5..... Link to comment Share on other sites More sharing options...
SpecialWarr Posted September 9, 2014 Share Posted September 9, 2014 hmm... did you try changing just the wire from #5 to another cylinder? I can't think of anything else other than a basic leak-down test, but is there a timing ring in the distributor like on the WD21? It MIGHT be dirty/ bent or its wire?? I'm just throwing stuff out there man.... best of luck! Link to comment Share on other sites More sharing options...
anperalta Posted September 9, 2014 Author Share Posted September 9, 2014 (edited) Yes i do change only the wire to.... and nothing... i also remove the valve cover to check for a stuck valve but all looks good to..... so im realy confused.....noob question....what is a basic leak down test??? Jeje any other idea will be appreciated.... saludos.... Edited September 9, 2014 by anperalta Link to comment Share on other sites More sharing options...
Rebelord Posted September 9, 2014 Share Posted September 9, 2014 Pump it up to 150 psi and let it sit. See where it drops to. Should hold higher than a certain amount. Will be in fsm Sent from my Moto X Link to comment Share on other sites More sharing options...
anperalta Posted September 10, 2014 Author Share Posted September 10, 2014 (edited) Well its already at the meca.... he will be inspected the egr valve.... Edited September 10, 2014 by anperalta Link to comment Share on other sites More sharing options...
anperalta Posted September 13, 2014 Author Share Posted September 13, 2014 Looks like the mechanic it's a little lost to.............. 3 days at the shop and still not found the problem........... is not spark, is not spark, fuel neither compression....... clogged injector? I really don't thing so! Link to comment Share on other sites More sharing options...
Kingman Posted September 14, 2014 Share Posted September 14, 2014 Leaking intake manifold gasket? Link to comment Share on other sites More sharing options...
