chill7696 Posted July 24, 2014 Share Posted July 24, 2014 i was looking at an ironman suspention lift for my 01 and was wondering if it would be cjeaper and better than just getting taller coils and new struts any recomendations? Link to comment Share on other sites More sharing options...
bushnut Posted July 24, 2014 Share Posted July 24, 2014 the iron man lift is a taller/stiffer coil, however not sure where you're going to find them, as there North American distribution seems to be in limbo right now. If you do find them I highly recommend them, the ride is great. though you will want to use a 1 to 2 inch strut spacer to level out the truck, the front springs only lift about 35mm while the rear lifts a little more than 50mm(designed to aid in handling heavy loads) 2inch longer than stock rear shocks will be necessary as well. As for struts KYB seems to be the standard, Rancho used to make some not sure if they still do. Old Man Emu would be my choice next time. Ultimate Suspension Systems out of Australia might be a choice as well. Link to comment Share on other sites More sharing options...
chill7696 Posted July 24, 2014 Author Share Posted July 24, 2014 would the spacers from 4x4 design work? and sick lookin rig man Link to comment Share on other sites More sharing options...
bushnut Posted July 25, 2014 Share Posted July 25, 2014 absolutely! top notch stuff. Link to comment Share on other sites More sharing options...
chill7696 Posted July 25, 2014 Author Share Posted July 25, 2014 haha thanks man ill look in to it Link to comment Share on other sites More sharing options...
svar Posted August 1, 2014 Share Posted August 1, 2014 the iron man lift is a taller/stiffer coil, however not sure where you're going to find them, as there North American distribution seems to be in limbo right now. If you do find them I highly recommend them, the ride is great. though you will want to use a 1 to 2 inch strut spacer to level out the truck, the front springs only lift about 35mm while the rear lifts a little more than 50mm(designed to aid in handling heavy loads) 2inch longer than stock rear shocks will be necessary as well. As for struts KYB seems to be the standard, Rancho used to make some not sure if they still do. Old Man Emu would be my choice next time. Ultimate Suspension Systems out of Australia might be a choice as well. Hi Bushnut, I have question regarding the spacer, in front is 35mm and when is settled is like 1" and the back is 1.5" settled? in that I can put in front 1.5" spacer and the back 2" when the ironman are settled I may right? thank you for your inputs provided. Link to comment Share on other sites More sharing options...
bushnut Posted August 2, 2014 Share Posted August 2, 2014 shouldn't be a problem....I'm going to be installing another 1 inch spacer (4x4desingns) on top of the one I have (nx4)up front to level things out as the front Iron Man springs have settled more than the rear. I'll post pics when I'm done...though it might not be for a while yet. Link to comment Share on other sites More sharing options...
